Sorry for my english[:">]
How I can update memory on my vaio?
My VAIO: FS115ZR, there instaled two 256 mb modules,
I want to replace them with new 512 modules.
1) If I buy new memory modules, what I must do with old memory.
2) Can I myself replace memory, or this work must be done in service centre?
3) How I can buy new memory, if sonystyle don't work in russia?
Thank you.
1) Keep them until you know the new RAM works
2) You can do it yourself the instructions are in the manual.
3) Not sure if crucial.com will deliver to Russia - you'd have to check. Otherwise buy some Kingston RAM for a local site.
And what about warranty for my vaio if I replace memory myself?
And when I know that my new memory work, what I must do with old memory, can sony buy it?
Thank you
No problem,
good luck!
