I have a vaio PCG-K315M and I'm looking to upgrade the memory from 512mb to 1gb. In the manual it says only to use PC2100 -DDR266 ram but when I had a look to see what was installed already the memory was labelled as PC2700. Has this been labelled incorrectly? Does anyone know which type of memory I should buy?
Thanks
Eddie,
Crucial has a good memory finder for VAIOs, check that out.
Their memory is good and not badly priced.
