Hi Claire and welcome.
Can you tell us the type of Memory Stick - it will be written on it.
Please also tell us which Sony Vaio model you have and what version of windows it is running.
Thanks
Hello,
Thank you so much for coming back to me
My sony is VPCEE2E1E and the stick is a HP Flash Drive v125w
Please let me know if you need anything else...and this will be a life saver!!
Claire.
This is probably a really ditsy comment yet how do I find out which version of windows I am running?
Your Vaio was sold with Windows 7 installed and your HP memory stick should work OK.
Have you used it before?
Where are you looking for the drive to show up on your computer? Try plugging it in, right-click on the START icon and choose 'Explore'. Scroll down in the 'Folder' box to the bottom. Does your HP Drive show above 'Network' and below 'Windows'?
No..it is not showing up at all and then I am not sure how to access it to save files on it 😞 I haven't used this one before yet I did have this issue before with a stick 😞
Thanks for your help...it's really appreciated :))
