Just a quick note to advise you all that you MAY encounter problems installing software onto Memory Stick Pros. There is a difference between these and normal White and Blue sticks.
Although therer is updated software on Clie-Link, this does NOT always address the issue. Check before you buy software if you wish to install to Pro.
