I have increased my memory from 512 to 1024 on the A297XP with XP Pro. I was wondering if I should change memory settings on the system to make the most of the upgrade or leave it as it is?
Any suggestions welcome
Thanks
Phil
You should just leave it as it is. You could try changing Windows virtual memory settings if you like but any changes will only give marginal, if any, improvement.
