hello, i ve got VGN-FJ1S Laptop and want to increise its memory , could you tell me that if i can use this one ---------- """512MB DDR2 PC2-3200 400MHz Memory Module (Brand New) - This is an Unbuffered, 240 pins 512MB DDR2 PC2-3200 CL3 400MHz HYS64T64000HU-5-A Memory module""-----
thank you
Hi balantre and welcome to the forum.
That module would appear to be compatible with your model but I suggest that you visit Crucial.com and use their system scanner to determine whether your existing module is PC2-3200, PC2-4200 or PC2-5300. Your system will operate at the speed of the slowest module.
thank you
