Hi all
I have a AR21M, it has, as you are aware 1GB standard.
Its running extremely fast at the moment.
I also have 'Free RAM XP Pro' programme running in the background (Tried others too, they all say similar!), I
It shows that most of the time i have only 25% RAM free, this sometimes goes down to 10% with quite a few apps. running at the same time.
Would i notice a big difference in speed/performance with another 1GB installed?
Lee
Well. in theory yes, but as you're only using 250 give or take, then it's going to be the same with 2GB, except that'll be a smaller percentage.
I'd say upgrade if you want, specially if you do video work (and why not, it's so top-of-the-range it would be a crime not to induldge in HD recording) or 3D rendering.
