Dear memebers,
I would like to know if anybody found a solution for the memory card reader VGP-MCA20.
I read somewhere that the best option was to buy a new one as there is a design problem with this card reader. Is this the case?
Or is it a driver/software issue?
I have also read that if you press the card your laptop recognises the it. In fact i have tried this option and it worked but only for my 1GB card but not for my 4GB card.
Is there a limit for the card capacity?
Did Sony fixed this issue?
