Hello,
at first sorry for my english.
I´m a german guy and my english is so bad.
I have a problem with my memory card adapter in my vgn-fe11m.
I have two cards, 512mb and 1gb memory.
The 512mb card is useable in the adapter.
I can read and write.
The 1gb card does not run.
Windows say that there no drive is insert.
If i use an external card reader, it`s going.
Also in my pocket pc.
But why does it not going in the sony memory card reader ?
O god, i hope anyone can read my bad english 😞
Hello,
after 3 weeks, the problem is still there.
The Sony support are still sleeping.
They ask me things that i write before and now i wait until 1 week for an response.
The Sony support is the worst i have ever seen.
It's simple: The reader have a bad design.
Some SD cards have the methalic contacts more at the "edge" (of the plastic SD case) than others. For those SD cards, with tiny margins, works fine; for the others, with the contacts with a larger margin, don't.
Try yourself keep the SD Card full pressed with your finger within the adapter, and your system will read it for shure.
Before you buy a SD Card brand, try it If it works.
