HI!
I have a VAIO PCV RS502. How can I copy video files to DVD? (The videos are in divx format than I can't use clic to DVD).
Whit CD that's all fine but whit DVD it seems that I can`t use a simple copy command. Why???????
Please, help ma!!!!!!!!!!!!
Thanks
rox
You need to use Drag n Drop DVD
Make a data DVD
Or better buy a copy of Nero.
I have used Gigapocket to record the video then transferred them to click to dvd. This was used to record analogue video but I think it will work just as well with digital video.
The transfer is automatic.
