Mini VAIO (file transfer program)refuses to transfer-convert all kinds of files!!
I¿m working with my VAIO VGN-A297xp(win XP pro sp2),
tried to uninstall all programs and devises installed prior to problem start point, and also tried to recover the system rolling back to previous date.
Later I reinstall the VGF-AP1L software (SonicStage2.1+inclouded updates) in Vain.
Please help !
Ps .I also (Hard )reset the player and formatted the disk too .
What files are you trying to convert and what software are you using?
Music files? Sonicstage?
So, if I understand correctly, you are trying to convert MP3 to ATRAC?
SonicStage should do this without any trouble.
Tellngd,
That 's exactly the point!
Everything was working fine for a day or two.
Something went wrong and I keep receiving
¿Unable to convert file ****.mp3 due to unknown Error¿
Thank you, anyway.
Stelios,
Sounds like SS may have gone pearshaped
Try re-installing it - BTW make sure you take regular backups of your music database if you use SS as your main 'music manager' - it can be a little unreliable.
How about converting to WAV before ATRAC?
Have you tried getting the Microsoft update yet?
Have a look HERE, credit goes to Titane for discovering this link.
Good point James.
Sounds like SS may have gone pearshaped![]()
