Hi, The sound on my new VGN-C2S seems very low has anyone else the same problem? Is the only fix a set of active speakers? Regards co2laser.
Thanks for your reply Matt, done that and it's better. Thanks again
Can I do the same for my VGN-C1S? My volume's also extremely low on some applications.
Wow - that's better. To think, I'be suffered in virtual silence for 8 months........
Cheers Matt!
Cheers Matt!
I have VPCS13S9E and cant find that setting in BIOS. I come in with F2 but how to find the settings in BIOS? I have gonne through everything i think but nothing about sound.
