Having got my dvd drive back, my cat jumped on the keyboard in add/remove progs and I have lost vaio zone. tried recovery tool, but it states that I have deleted the partition?????? News to me.
Any solutions? as slowly loosing my mind.
J
Did you create recovery disks?
Yes,just found those. Installed zone again, but still does not work. Is there more than one progam to install?
I would make sure you have Sony Utilities and SonicStage installed.
Do you get any error messages?
hoorah! Its fixed! Thanks again for your help! Sill won't record TV though.....dho! Still I guess I just have to live with that.
Kindest Regards
Julie
make an application recovery only using the application recovery disk or turn off the computer then restart it and press F10 then choose...
