lost recovery kit
arnouk
Visitor
lost recovery kit
I have erased the recovery partition but burned it on DVD-Rs - unfortunately I have damaged the first DVD-R. Meaning that I cant re-install the original software. Is it possible to re-order a DVD recovery kit from Sony or anywhere else?
My VAIO is a FE11S!
If anyone knows - please let me know!
Thanks
2 REPLIES 2
HateBreeder
Visitor
My VAIO is a FE11S!
Thanks
I'm not sure if you can re-order a cd recovery, you should try it. The one thing i know is that you can't get it from anywhere else. Good luck!!
profile.country.GB.title
Thalamus.
Champion
My VAIO is a FE11S!
Hi arnouk,
You can order via vaio-link a set is approx £55.:smileysad:
