Hello!
My Alps Pointing Device on the pcg-fx604 has two important features less, since I updated the driver to version 5.3.510.9 :
1) I cannot close windows by making a diagonal move from the upper left corner down to the middle of the touchpad anymore.
2) I cannot minimize windows anymore by making a move along the left side of the touchpad starting in the upper left corner.
That sucks, since I used especially 1) constantly and it saved a lot of time!
Is there any way to repair this?
Cheers, edot
Rollback the driver
If rolling back the old driver doesn't work, then use the driver supplied from C:\Drivers or if you cannot find a Drivers folder here, visit VAIO-Link and obtain the Original Drivers Package.
Everything's ok again. Thanks!
At first, I was a bit worried, because in the meantime I had installed sp2, and because there was the message when rolling back that the logo test had not been passed, but there was no problem at all.
Happy again, cheers, edot
