x
Limited connectivity and dissconnect
SOLVED
iansythes
New
New sony laptop for xmas and connection drops with "limited" appearing in wireless strength box.
Other laptops in house are fine. My router is 8 feet away in same room.
Turned off power save etc. Did all the easy fix options to no avail.
If someone can post and paste a fix using EASY stuff for non computer expert like me that would be fabulous.
Most dissappointed.. my last laptop was 12 years old.. tired and so was getting myself a treat... I already miss its noisy fan as I never had this problem.
Connection can be restored by dissconnecting , turning on airplane mode then doing the reverse to reconnect.
help please..  contacted shop and they said this is a windows 8 issue and nothing to do with SONY so nothing they can do.
1 ACCEPTED SOLUTION
Accepted Solutions
pegylaptop
Explorer
Hello!
for the problem : Wifi connection 'Limited' try this
https://ca.en.kb.sony.com/app/answers/detail/a_id/43725/p/48903,4990,74253,85577/c/65,67/kw/43725
and this
http://www.fixedbyvonnie.com/2013/10/how-to-fix-limited-or-no-connectivity-wi-fi-issues-in-windows-8...
from the second url i tried the 2. Wake up your Wi-Fi Adapter and the 3. Enable Download over metered connections
until now everything looks fine ... i have 2 days to see the "Limited connection" ...
3 REPLIES 3
profile.country.GB.title
Nobody-in-particular
Contributor
Hi iansythes you haven't said what Sony laptop you have but I would suggest checking if there are any updates available for your Vaio. Updates can be found by entering your Vaio model number into the box on this link.
iansythes
New
hi
sorry i have the laptop number in battery compartment,  the laptop is a.
svf1521a2ew  hope this is the right identification number
pegylaptop
Explorer
Hello!
and this
