hi, i bought a new T2XP, after switching on there is delay before the main page comes on, any suggestions?
We really need more info
More information is that when i switch it on the welcome screen comes up for 1 min, then the XP wallpapaer comes up then the programme start loading. Any suggestions?
Erm, this is just the way windows boots up... its completely normal, dont expect it to load everything instantly.
Hi Beardo,
Correct me if I am wrong, but should that not be MSCONFIG.EXE and not REGEDIT.EXE?
REGEDIT.EXE Edits the Windows XP Registry (best for advanced users)
MSCONFIG.EXE Allows changes to Windows XP Startup
Start > Run > MSCONFIG (press Enter) > Selective Startup > Untick Load Startup Items
Or
Start > Run > MSCONFIG (press Enter) > Startup Tab > Untick everything.
For the people who like REGEDIT.EXE better (PLEASE back up your registry first though), navigate to
HKLM\SOFTWARE\MICROSOFT\WINDOWS\CURRENTVERSION\RUN
Deleting keys + values here has the same effect as unticking the boxes in MSCONFIG.EXE - but MSCONFIG has the prettier and easier interface.
Start>Run>Regedit>Startup and untick anything that is deleted or just a waste of time and reboot twice after the diagnostic mode has been satisfied.
He does have a point Feederfan, it's a bit slow, mine usually takes around 20secs
The T2XP has a 1.8 inch hard drive & a 1.2GHz Pentium M so it takes a little longer to start up.
