Hi my laptop wont turn on the last time I used it was Saturday. I've tried removing the battery, plugging in the charger but no joy. None of the lights will turn on even if the charger in inserted. Please help!!
Hi there
Try doing a power discharge:
Hi there R00056164,
How frustrating! Someone from the Community may have some ideas for you to try, but if not, I recommend contacting Sony Support and they will be able to assist you further.
Thanks,
Pascale_F
