does anybody else have problems with machine overheating after a short time?..it is impossible to keep unit on your lap for longer than ten mins,as it gets very hot to the right of the unit
Hi jodaz and welcome to Club Vaio.
There have been a number of recent posts relating to heat problems with the BX series. No solutions to date but at least you can rest assured that you are not alone with this problem. Try a search of this forum – sorry to be of little help with this.
There is a bios update avalable for all bx series from the vaio-link site
All this after I recomended them......... sighs
Have you seen the position of the intake for the cooling fan?, the chances are that if you have the laptop directly on your lap you will be blocking the air intake dont do it.
I know, it's badly positioned
