I usually use my wireless to connect to the internet, but I'm staying in a hotel at the moment that doesn't have wireless, so I'm having to connect via a cable.
But , my Local Area connection isn't working properly, it isn't recognising that I've plugged a cable in.
Is there anything that I can do to rectify this ? Is it to do with my drivers or something ?
Thanks.
I can't use a cable (dsl) to get on-line basically, the local area connection isn't seeing the cable when I plug it in.
It see's it for a milli-second then cuts off.
As i'm in a hotel that doesn't have wireless, it's a bit of a pain.
Could it be my firewall or something ?
I go on to the properties page for the Local Area Connection & it say's that everything is working properly.
So, i'm not really sure if there's a fault or it's something that's wrong with my pc.
Any ideas ?
Thanks.
