hi, ive got a problem with my keybord , all the letters work and most of the signs work too , only when i want to type this sign "_"i get this sign "!", how do i configure the keybord so this problem would be gone , thanks
Probably something to do with your language settings. Maybe you've got American or some other variation of English set up? You can check/change it in Control Panel.
Yep, in Control Panel > Regional Settings
