can anyone tell me where i can find the keys on my italian keyboard explained? i have a vaio notebook
vgn-fe11h
qualcuno potrebbe spiegarmi dove trovo la spiegazione dei tasti sulla tastiera italiana?
thanks
Hi sca and welcome to the forum.
I assume that you are having difficulty in configuring the keyboard to your language.....In control panel double click Regional and Language Options, click the Languages tab > Details (this will take you to a settings tab). Click Add (and select both your keyboard layout and input language from the drop down menus, click OK which will return you to the settings tab.
Under the ‘Default input language’ drop down menu select the keyboard layout and language that you have just created and click OK.
This link should help you identify your keyboard layout.
