Hello, i have the Sony Vaio PC-8131M model for 2-3years now.
I started with Vista, when i decided to do a format because the system had started to be weak.
I installed windows 7 and everything was ok until the day that keyboard went crazy.
Some times it is working fine, some other is writing what it wants.
The most common issue is that while i am writing something, it moves somewhere at the middle of the sentence by itself, some other times it pressing its own buttons like enter/shift/tab and whatever.
I tried to update the driver and it says that is up to date.
Its really annoying to write a big amount of texts with this keyboard now or even put some usernames/passwords.
Is anyone faced same issues in the past and found a solution?
Thanks in advance.
Problem still exists, anyone can help out?
