My tracker pad and buttons gave up working over a year ago, I came to terms with that.
But now my keyboard stops working every 5-10 mins and I have to restart.
Is this something that can be addressed with a driver re-install?
Please help as my laptop is turning into a desktop with all the usb inputs!
Thanks.
(Vaio VGN-NR21M running Windows 7)
I have the same problem on my VGN-BX396XP also running W7. I used to restart and it would magically spring back into life but have since discovered that entering sleep mode and then firing the laptop up again will also clear the problem (until the next time) Come onSony, whats the solution??
