has anyone experienced problems with the keybords on VGN-FS115Z or any other vaio. When i sometimes press the "w" key, i get "wt"//d" or some other crazy stuff apear as text. Is there a function key that keeps kicking in???
Get a can of compressed air and spray under the offending keys
You haven't pressed the 'Num Lk' key in mistake, by any chance? Located on my machine - top row, 4th key in from right. Also check language is UK English and not American.
Good luck
