Hello, I have recently downloaded XP SP2 for my W2 and the following message keeps appearing.
I have visited Sony site but don't know where to look.
Can anyone help? Ta! :
Keyboard Closure Set Up has a known compatibility issue with this version of windows and might not runn as expected,,,
hello
Don't know where to look or what to look for
Look in utilities
Tutti, did you fix the problem, ive just intalled sp2 and have the same problem... cannot seem to find a fix....
I found I had to Remove the Key board thing from the start up , Before the following ;; Stopped
Sorry I cant put it any other way , I feel dizzzzzyyy today
just been testing things out, its not that bad, if you flip the keyboard into dvd/tv mode gigapocket still starts and seems to work fine, the remote still works so thats okay....
its just it dosent go into clock/standby mode when you shut it which isnt too much of a prob for me as i always hit the power button to put into standby anyway. then i know the aeroplane engine inside stops....
Nope, still the same...
