Just a quick question, what is the best way to keep the A117s screen clean, I understand that it has been chemically treated by Sony so don't really want to use a standard tft screen wipe incase it damages the screen...
Can anyone please advise
Thanks
A lint free cloth with a sprinkile of water (not too much mind you, enough to get rid of marks / dust)
I have the same model laptop, and the first time I tried to clean it I used some antistatic glass cleaning stuff this WAS not very good, the day after I bought some bandex laptop screen cleaning thing and its just perfect, so thats what I prefer it is a little bit expensive but for this screen I dont have a problem using a little bit extra..
An expensive screen needs expensive cleaners.
Great thanks guys, so a tft screen wipe should be fine then
Yes that would be just fine, and remember to make sure that it is for tft and not crt:)
Make sure they don't have alcohol either.
