I'm getting sound problems on my vaio VGN-FS415E. I don't know what to do. I think i'm best starting afresh. But I thought, I don't have a XP cd so how am I able to start afresh? I have a Vaio recovery utility on my pc that says it will restore the laptop to "its original factory state" what does that mean? Is it when I purchased it? like with all the trial software on it and xp installed ready for me to set up?
Please help, i'm really nervous.
Sorry, I don't think i've worded that very well. Basically what I mean is if I use the Vaio recovery utility will my pc be the same as when I turned it on for the very first time of purchasing it?
Also is it easy to use the Vaio recovery utility? I have two hard drives, will this make the process easier or harder?
If anybody could offer me help and advice i would be very happy.
Don't be, as you said the factory defaults means like the day you bought it.
Thanks Kee-Lo. Can I ask, is it an easy process? and do people resort to using it often?
Thanks
it's very easy, and it's meant for anyone to use, no matter what skill level they are at.
A lot of people have done it here
Thanks for the help and support. I'll be looking to do it within the next hour. However there's just one final thing
Once I go through numerous options I come to the "Recovery menu" Its asking me whether I want to recover drive C, C and D (change partition sizes) or finally a complete recovery. Which do I choose if I want everything back to it was the first time I turned my vaio on?
Thanks once again
You want complete recovery.
Remember to back up your emails and favourites, oh and files you cannot replace (photos, documents etc)
Will do. Thanks for all the help. Will report back later will news of a successfull recovery
I'm all present and correct. Thanks for the advice and reasurance Kee-Loo.
No problem Lawrence
