hav just been playin with pocket vaio came across jackets? can any 1 explain, also can u make a new folder 4 pics 2 go in?
You have to connect your VP with computer and it should apper as a removable device or disk. You then click onto it and go to folder Vaio Photo, Open folder by double clicking go to File on task bar click on New Folder and rename it USER_001 (etc. etc.) Presto!
wrong....
you cany change the name of the folder. sadly!
Simple.....
Connect player to PC....go into vaio photo folder.....add new folder...rename it USER_002....
Whenever you make a new folder it must be named as USER_
followed by a number, its the only way the player recognises the folder....sony software?!:smileycry:
