i bought a grand tv usb 2.0 adapter to watch tv on my vaio (pgc-fr315-s)
this should be usb 2.0 compliant. The system resets every time it receives some video signal. On the manual of the device they say that i must see something like USB2.0 Root Hub on the device window in control panel-system hardware devices
This simply does not happen!
Q1: is my vaio really USB 2.0 compliant?
Q2:does exist a program able to detect which kind of USB i have on my computer?
Q3: has anyone mounted successfully a grand tv usb 2.0 device?
you can check that by looking in your user manual or just look up the specs at the sony webpage. (do i really have usb 2.0?)
have got any drivers with that tv box? have you checked the website of the company making your tv box for updates or known problems?
Check in Device Manager. It will be either USB 1.1 or USB 2.0
Good luck. I was expecting mine to be 2.0 as it was a new model last year but it turned out to be 1.1
Im just happy it has FireWire.
Probably an error.
Always double check with the vendor.
