I have deleted my IR remote from device manager by error, Is there any way to reinstall from my recovery discs? thanks.
Hi Blencogo,
Just had another dig around in device manager and found that "consumer IR device" in system devices was disabled, have enabled and success! remote now working.
Many thanks to yourself and Rich for your time and effort, it is not wasted as I have learnt much more about device manager, drivers and windows media center, because of this issue.
Once again thank you for all your help.
Regards
Maureen
Hi Maureen,
Got there in the end - well done!
