Still having problems?
It seem after I update from windows?
what do I need to do?
NIS -Intrusion Detection is disabled and won't turn on again?
Help, before the laptop goe's out the window!!!:smileydevil:
Hi Jackie,
Sounds like comething has got into your system so:
1) A full AV scan is required
2) Download Spybot S&D from http://www.safer-networking.org/en/index.html
3) Get ad-aware from lavasoft.de
I recommend that you use an online virus scan if you think the computer has been compromised. Try http://housecall.trendmicro.com/
