Hi all,
I have a Sony Vaio running Win7.
I have recently been having issues with my internet connection. After a couple of hours of normal use (browsing/downloading/streaming etc) the ineternet will stop running. I show up as still connected with 'excellent' signal strength however, when I try and load a website in firefow/chrome/Ie9 it will not load.
I did have Soluto on my PC but have uninstalled this thinking that was causing the issue but the problem is still there. I have also had a look at the firewall etc and all seems fine.
I then thought it could just be my internet, however I could still browse using the wifi through my phone, and i also have take my laptop to various peoples houses and tired the wifi there however I have the same problem. It is like the laptop suddenly decides to block the internet.
To get the internet running again I must restart the laptop and then continue from there.
Would really appreciate some help with this as it is getting quite annoying.
Thanks
Raman.
PS I have tried a system restore too but am getting the same issue.
