I cannot define Interent Explorer as default browser on my Vaio (I know that thsi is unusal as question as more frequently the users look how disable IE).
I define it either by answering the explicit question or by changing the parameter using Option menu, but when I launch it once again it asks me still the same question and when I check the options, IE9 is not tagged as the default browser.
Any idea what is going on?
Vaio3D
Message was edited by: vaio3d
Sony set Chrome as the default browser and sometimes it is difficult to change. The usual methods do not seem to work.
I am sure I simply downloaded the IE9 upgrade from the Microsoft website and during installation, set it as the default browser. It seems you have to download a new browser to be able to change the default.
I have since changed the default browser to Firefox without any problems.
Thank you for your answer.
I want to set IE9 as default browser because it seems to me that I know better how to protect my privacy with it.
With Chrome, which I found well done, I have an impression to receive too much of targeted advertisements, thus I have a feeling that the "Big Brother listens”.
I downloaded both IE9 and Firefox defining them as default browsers, but with no effect.
That is strange - let's see if anyone else has a fix.
