once i disconnected from an unknown network and when i did that intel wireless display shows that adapter not found!
how to solve this issue?
Hi infotech.jalal,
Is the wireless adaptor present in Device Manager and if so are there any error messages or unknown devices listed?
Rich
Message was edited by: rich912
thank u rich for replying
yes the adapter is present in device manager and seems to work properly
no messages shown any where except the one when u open ur wireless display the app. shows adapter not found.
i tried to search in services and i tried to start (wireless pan dhcp server) but error 1067 occured and the process was terminated...!
is that server engaged anyway?
Hi infotech.jalal,
It would be possibly be better if someone running Widows 7 OS with a similar model offered help as I am still on Vista.
Let us know your model number, but in the meantime a few suggestions for you to try/investigate:
Check that the wireless adaptor is enabled in Network Connections.
If your model has Vaio Smart Network software make sure that WLAN is enabled and set to 2.4GHz only.
Check that you have not inadvertently moved the wireless switch to the off position.
Try running the Intel Manual Diagnostics Tool (assuming that this is installed)
You could try uninstalling the wireless device driver and then reinstall.
Rich
