Hi rich912,
I totally understand with what you are saying and thank you for replying with your suggestion, I'll give it a whirl and see how far I can get, I'll also try the preinstalled apps from the sony pages as well.
Many thanks,
Timbuctoo
Hi timbuctoo,
The pre-installed software is only licensed for the original OS unless you do an in place upgrade as opposed to a clean install. The disks you created are only intended to reinstall the system, drivers and pre-installed software back to factory condition.
To open .pac files you will need to Google ‘kcap unpacker’. Some members claim to have had success with this but unfortunately Sony considers this to be piracy so we are unable to provide further help with this on the forum.
Rich
Good luck Timbuctoo
Thanks Rich
Worked for me in the past and there used to be a detailed How to guide available.:smileywink:
