hello,
i have make a error i have erase a file for the vaio media center and it doesn't work.
is it possible to use the cd restore to install only this program.
thanks for responses
laurent
On my recovery CD I would somehow need to manually unpack them.
In my case it would be easier to go to Vaio Link and download the latest media centre upgrade. Hopefully the deleted file would be reinstalled.
VAIO LINK
Assuming that you have the VAIO recovery Utility, have a look here.
