Was using VAIO Update to update the Sonicstage Mastering Studio. Followed all the instructions (@ http://www.vaio-link.com/vu/vu21/info.asp?l=en&ip=SOASMS-01200700-UN.htm) vut recieved a message stating 'A same or newer version is already installed. You do not need to install this version'. Fair enough I thought, so tried to use Mastering Studio but now when it loads, I just get a blank (black) screen.
Can anyone advise?
I did try and uninstall (via Control Panel, Add / Remove Programs) but recieved the following message.
An Installation support file could not be installed. The system cannot find the file specified.
Thanks for your help.
