Hi Guys,
Any way to take off the Remote Control from the VP and plug some earphone directly to this as I don't normally use the Remote Control.
Thanks...
Yes !!! Like most sony products with inline remote a standard mini headphone jack will work in the same connection on the VP also non sony headphones can be plugged in to the inline remote
No, I meant I don't want to use the In line remote control. I need a kind of earphone (headphone) extention plug that fix directly in the VP and not in the remote control so I don't have to use it any more.
Thanks...
Thanks...
Thanks a lot guys....
