can you please help me?
i would like to recharge my pocket vaio in my car. is there a suitable in-car battery recharging device? if so, where can i buy it in u.k? many thanks for your help.
Have a word with the Lap Top Shop , nothing is listed for the Pocket but you never know.
Otherwise an inverter may be the solution (bulky, but will do the job).
Something like this.
I think i saw in a earler post that the In-car charger for the Tom Tom GO GPS works as it is the same 5.2Volts about £20 in Halfords.
thanks a lot for your suggestions.
but does this not mean that you also need your cradle in the car as well.
the cockpit of my car is very small, hence the reluctance to have the cradle, the charger and then something to connect to the stereo with.
any views on the neatest set of accessories to do this?
