- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
Imaging edge update
Tethered my A7III to my Macbook Pro using usb C cable. Working fine. Then I notice there is an update for Imaging Edge. Download it, install it and then...
Sony Imaging edge is now telling me " The document A7300001.ARW could not be opened. Imaging edger desktop cannot open files in the "Sony ARW raw images" format.
If I change from recording raw to jpeg in camera, it gives me the exact same message, but substitute ARW with jpeg.
Is this a bug ? can I roll back to a previous version of IE ?
No settings were changed on the camera between working with old IE version and new version.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi @Normski4ash, try using different devices and cables, if the issue remains, you need to contact Imaging Edge support directly, they'll be able to assist further. You can contact them on 02035382665, or via the help page: https://www.playstation.com/en-us/support/
