Imaging edge update
profile.country.GB.title
Normski4ash
Explorer
Imaging edge update
Tethered my A7III to my Macbook Pro using usb C cable. Working fine. Then I notice there is an update for Imaging Edge. Download it, install it and then...
Sony Imaging edge is now telling me " The document A7300001.ARW could not be opened. Imaging edger desktop cannot open files in the "Sony ARW raw images" format.
If I change from recording raw to jpeg in camera, it gives me the exact same message, but substitute ARW with jpeg.
Is this a bug ? can I roll back to a previous version of IE ?
No settings were changed on the camera between working with old IE version and new version.
0 REPLIES 0
