I have an S series vaio pre loaded with windows 7 and IE 9 beta every time i try to print from the internet i get a message Ie has stopped working. i have tried loading IE 9 RC version - same problem . Does IE 8 work with Windows 7 ? Any ideas please ..... Seems to be a common problem but have not seen any fixes !
This sounds like an old problem with IE reappearing. What anti-virus are you using (previous problems were with AVG)
Does it print if you turn Protected Mode off? (IE) Tools -> Internet Options -> Security -> Internet Zone -> Uncheck Enable Protected mode?
Have you tried the automated fixes available from Microsoft?
http://support.microsoft.com/kb/973479
