Hi
The problem is that i dont know which cord i should buy. I have a VGN-NR11S and it has a VGA contact. I have seen a couple of them on the internet but they all have the two screws at the side and i dont think that will fit on this computer. So where can i buy the cord that i need?
Im sorry for the bad english and i hope you understand my problem.
Thanks
Hi Seedorf and welcome to Club Vaio.
What input connections does your TV have?
Unless your TV has a VGA input, you will need a converter box.
Hi
My TV does not have any VGA input connection. So whats a converter box and where can i buy one from the internet?
Thanks for the help
You will need something like this adapter VGA to S-Video/Composite Video: -
http://www.mediaatlantic.com/product.php/759/0/
You may find it locally by Googling for AverMedia AverKey Lite.
Thank you very much! :smileygrin:
