hej! everyone.
i bought the vaio new laptop and I am just enjoying it.
so i am tempted to install and claim Vista.
I just want to know , while i want to claim it ,This windows starts to get upgraded?? or I get a file and i can install vista later?????
my concern is that what happens if Vista can't go well and how can i bring my current media center back to life ???
any clue is appriciated! thanks.
Hi
You get a DVD from Sony, this will upgrade to Vista (usually with not much interferance from the user, which is good)
Make sure you back up all important data before you start.
If you have any problems during the upgrade you can always use the HDDR to get back to normal.
Hello I really appreciate if you could tell me how I can get the new windows vista cd from Sony... do you have to buy it as I got AR 21S and windows vista capable, thank you.
