Hi
I want to remove the recovery partition to have more disk space.i have wrote the recovey disk's and now the recovery partition is useless.
Hi
Hi George.m,
Back up all important data and create at least two recovery disc sets before you remove your Recovery Partition. Then make sure you recover your Vaio using the Recovery Discs that you have created, this will ensure that the disc's work correctly..
Here is Sony's guide on removing the recovery partition..
Thanks thalamus and huntuibui
But i will lose any data?
ps:sorry for my english
:smileygrin: Mery chrsitmas to everyone :smileygrin:
Hi George.m,
If you use a third party program such as partition manager your data should remain intact, however, should you need to recovery your vaio in the future and discover that the Recovery Disc's you have created do not work then you would need to purchase set from Vaio-Link (approximately €112)
ALWAYS back up when playing with Partitions, it can go sour!
Thanks for the advise.I will waiting for a recovery then to test my recovery disks
______________________________________________
:smileygrin: Mery christmas to everyone :smileygrin:
You're welcome, good luck..
