my laptop doesn't start anymore... It seems that "boot.ini" file has been corrupted (after "partition magic" use...)
windows does not start anymore. And I cannot open the dvd reader to put a bootable CD. (It seems to me that it can be opened only when you have open a windows session)
So what can I do ?
1/ use a trick I don't know yet (to learn) to manage to open the dvd reader, and then put a bootable cd in it (such as windows cd) and then correct the corrupted file (boot.ini) ?
2/ take out the hard drive and put as a slave on another pc and correct the file suposed to be corrupted ?
What are your ideas ?
There is a tiny hole at the drive. This is a button.
Seb
Too many beers?
well, i had a long night.:smileyblush:
Hehe
I was just reading the original post, thats why I don't suggest PM, it destroys PCs (In my opinion anyway)
thanks for the information.... it seems it was well-known ....!
i repared my pc ....
