How to disassemble my VAIO?
Fraker
Visitor
I would like to disassemble my VAIO FR102,
could you help me please?
13 REPLIES 13
VAIOneer
Visitor
Why would you like to do this Fraker?
Fraker
Visitor
the fan is very noisy and the CPU is becoming very hot sometimes, so hot that it is turning down itself.
I would like to check the fan
VAIOneer
Visitor
Well as long as its not under warranty and you're sure you'e capable of the task, you will have to find retaining screws/clips to remove the keyboard and take it from there.
I can't say anymore as I have never done it
Fraker
Visitor
Ok, thank you. I´ll try later and will give some news as soon as I´ve done it
Fraker
Visitor
Can I use Power Panel with my Vaio?
profile.country.en_GB.title
tellingd
Visitor
Taking apart any laptop is tricky due to everything being crammed together. Sony like to complicate things by 'hiding' some of the screws :thinking:
You might want to allow yourself considerable time for this task, and a LOT of patience.
VAIOneer
Visitor
Yes you can :slight_smile:
Suprised its not installed already
Fraker
Visitor
It seems that my computer doesn´t support this software because it wasn´t provided with my laptop. That´s why I ask this.
Moreover, does SONY provide a manual to disassemble laptops if asked?
VAIOneer
Visitor
Extremely unlikely.
