I have the laptop model written in the title. I can't seem to be able to turn off touchpad on it as it's very annoying when I'm typing and it jumps to a random place thus distracting and annoying. I go to PS/2 Compatible mouse properties, and the disable function cannot be selected. How do I turn it off? Looking forward to hearing from you soon.
Follow this procedure to disable the touchpad.
Click the Start button, then click VAIO Support Central.
In the VAIO Support Central window, click on the Categories tab.
On the Categories tab, click the Plus (+) symbol next to Keyboard and Mouse.
Under Keyboard and Mouse, double-click Built-in Pointing Device.
In the Built-in Pointing Device window, click to clear the Enable box.
Click the OK button.
In the Built-in Pointing Device dialog box, click the Yes button.
_______________
Life is too serious to be taken seriously
The touchpad can be disabled in Vaio Control Centre.
Just go to Control Panel, then Vaio Control Center. Under Keyboard and Mouse there will be Built-in Pointing Device. Once you click on that a box will pop up and there you can click to uncheck the Enable box to disable the touchpad.
_______________
Hi this works perfectly the only issue it also disables the SD slot!
