Hi everybody,
I read carefully quick start manual, after that I downloaded the full manual from the site, but I haven't found how to modify playlists on my Vaio Pocket.
Would somebody please help me with following questions?
1) How can I add a full album (not just a track) to my playlist?
2) Can I edit a playlist deleting tracks or album?
3) How do I quick empty a playlist?
Please don't tell me that playlists can be created just track by track!
Plz!!!! I need your help now! tomorrow I'll start my vacations and I'll not have any more chance to read your answers for more than a week!
Thx in advance and Ciao everybody from Italy.
When you are in the album, group or cover section you have to hold the g-pad. Then you can put the hole album to the playlist.
The same is in playlist section. Here you go into a playlist press long on a trach you want delete. In the menu at the right side you can also delete the hole playlist or move a track up and down.
yes it works!!!!!!!!!! thx a lot!
.......... Why doesn't Sony write more detailed informations on manuals?..........
